Hi I am using infinity free hosting for this website, Domain name was - thetribag com now I moved it to triobags com
Of course it not so easy now. it is few hours after but I think something pointing in the wrong direction
I am unable to edit my wordpress intallation or what I am missing
Please let me know what I would need to change.
Hi Admin, thanks for that I think this missing link on the domain cause the error. Now I’ve added parked triobags > thetribag.com. However I am not able to select the new domain from the account section yet.
The error has changed now > ERR_TOO_MANY_REDIRECTS.
Many thanks
Cannot post more than 2 links but you can guess the URLS
# DO NOT EDIT THIS FILE DIRECTLY
# Create a new .htaccess file in your htdocs
# directory (or example.com/htdocs/ directory)
# to add your own rules or override these rules.
DirectoryIndex index php index.html index2 html
ErrorDocument 400 https://infinityfree.net/errors/400/
ErrorDocument 401 https://infinityfree.net/errors/401/
ErrorDocument 403 https://infinityfree.net/errors/403/
ErrorDocument 404 https://infinityfree.net/errors/404/
ErrorDocument 500 https://infinityfree.net/errors/500/
ErrorDocument 503 https://infinityfree.net/errors/503/
This rule is the issue. It’s created through the Redirects tool.
The Redirects tool is useful, but can only be used to redirect to other websites. If you try to use it to redirect from a parked domain to the domain it’s parked on (or vice versa), use it to redirect from www to non-www (or vice versa) or use it to redirect to HTTPS, then you’ll get a redirect loop. That’s because the currently redirect will send people to http://triobags.com even if they are already on http://triobags.com.
