After logging in with admin/admin if you select the Admin tab in the navigation for whatever reason the javascript assigned to the buttons is not activating, and on the last section “Assigned Work” the buttons arent even appearing. On my personal computer with xampp this all works perfectly, but after transfer into the host with FileZilla FTP its not exactly the same. What could be causing this? I know the javascript is there and the buttons are there in the code as seen below:
The javascript isn’t showing, because I believe you have added it in the config file or index, try moving the JavaScript into the admin.php page, and for any issues with the javascript, I wouldn’t know, You should wait for someone good at JavaScript, my forte is php!
Turns out is was some missing database columns/names issues, my fault thank you for the help! I wouldnt have noticed it was cut off after Remove Assigned Work if you hadnt pointed it out!
