Hi, can you add more languages to the VistaPanel, including Italian?
Thanks
Plenty of languages are already available for VistaPanel, it’s just that using them has not been implemented yet (properly).
To change your language, login to your client area and find your account username and password. Then, go to http://cpanel.epizy.com . Use the dropdown on the bottom of the page to select the language before logging in with the username and password.
Yes but… There isn’t Italian…
You’re right. I hadn’t checked for Italian myself because like you I had assumed that there are enough Italian speakers to warrant the language being included. I’ll try to check it.
Well, i’m italian and i’d be glad if that language is implemented. Otherwise i’m able to transtate something.
Hi,
Thanks for the new CPanel theme, but… Italian language isn’t so good… If you want, I can translate it for you!
Thanks
