they all have the same registration for domains when we do whois.
now my question is how is my cpu daily limits being hit if i barely use 5% of any type of data in a 24 hour timeframe.
it seem like the servers are having issues if the cpu limit is being hit within a 24 hour timeframe if the site barely uses any more then 5% of cpu usage or so.
P.S: I am not saying its a bad idea to host more, just seems odd that i be hitting cpu limit for different sites that is hosted on different servers that is using the same domain registration as this webhosting place does
Note that out of the domains listed there, only freecluster.eu and infinityfree.net are ours. The other two domains are not from us.
You can view your daily CPU usage statistics through the Account Statistics section in your control panel. The CPU usage is not reflected in any of the statistics in the sidebar. If you have any account on epizy.com, rf.gd or freecluster.eu which was suspended for hitting the CPU limits and you would like to know more about why that happened, please let me know the username and I can check if there is anything else I can tell you.
