I have set my MX record but i don’t receive emails
The issue and this variety are so huge.
Can you please be a little more specific as to which steps you’ve completed so far, etc.?
If you are using Cloudflare (cpanel integration), then you can’t receive email since Cloudflare breaks incoming email.
If not the case,
If you have added the record earlier, MX will take some time for it to propagate, so you will just have to wait.
If not the case,
I’ve tested the method provided here and I can vouch it seems to work perfectly @Dugglers:
https://forum.infinityfree.net/discussion/4076/sending-mail-but-unable-to-receive-solved-mx-records-cloudflare-both#latest
I followed these 2 simple steps:
1: Go to your CPanel Dashboard, create an Email Address account@yourdomain.com and enter a Password.
2: Go to your Domain Records and add the MX Record with the name of the account (account) and the value ofmx.epizy.com
Now go to your CPanel Dashboard and access your new email, test that the send and receive functions work.
Congrats, you’ve successfully established an emailing system.
works now
@Dugglers said:
works now
Great news. May you share what steps you took personally to resolve this issue for anyone else who may run into this problem in the future?
