MX Records for POP.CO Domain?
Can’t receive mails. What MX record should I add? The one given by POP.co or mx.epizy.com?
Where are you trying to receive the Emails? If you are trying to use an external email service you want the MX to point to them if you are trying to use the built in Email Accounts with InfinityFree it will need to be pointed to mx.epizy.com.
Best Regards,
Alan T.
Thanks for replying Alan.
So you’re saying, that we can receive emails without infinityfree?
Because the current email from infinityfree includes ads and bad spam filter.
Can I use POP.CO to send emails from my wordpress automatically?
Yes, you can use any external email service as long as you point the MX to them. If the Email Hosting provider allows POP, IMAP and SMTP you will be able to use the plugin “SMTP Mailer” to email using that provider. Link to plugin: SMTP Mailer – WordPress plugin | WordPress.org
Best Regards,
Alan T.
Wow! that’s awesome! Thanks for the info. I’ll get back if there’s a problem.
Thanks a lot
