can you tell me my mx records because by mistake i have deleted themm my domain is www.slipmoney.com
Have you checked the Email Accounts section?
yes
Domain MX Record Priority Actions
fvhuvmsr.epizy.com mx.byetcluster.com. 0 Delete
slipmoney.com mx.byetcluster.com. 0 Delete
slipmoney.com mx.epizy.com. 10 Delete
Hi.
I can not add an MX record (mx.epizy.com).
Can I add another record that is not from infinityfree?
@RevolucionWeb Are you also the owner of slipmoney.com? Because if not, your question has no place in this topic and you should create a new discussion for it.
yes i am the owner
by mistake i have deleted my one mx record
@slipmoneycom said:
yes i am the owner
My question was aimed at RevolucionWeb, because RevolucionWeb also posted in this topic despite the fact that this topic is about your website? I know you are the owner, I was just wondering why RevolucionWeb was explaining a problem with your domain name.
Your MX records are fine by the way. You can delete either of the two records for your domain if you want, but you should be able to receive email now.
