limitlessintranet.nl
If I visit my domain name it shows a very weird screen even tho it is connected with my website?
It is a template i use
Ok. But can you access the website?
It works now, i only got 1 problem. My site says it is not Protected?
Oh, realized that’s welcome page from your registrar. Sorry
Use a ssl. Connect it to Cloudflare or use ssl from the client area.
You can get free SSL from https://app.infinityfree.net/ssls
Choose Let’s Encrypt, type your domain, and follow the instructions
I think i got it but idk i will check
Multiple sets of nameservers were detected on your domain name. This is not recommended and may make your domain inaccessible.
What does this mean?
Check your nameserver in your registrar.
And while you putting epizy nameservers, you should remove your registrar’s nameservers as well. Don’t combine them
Move ns1.epizy.com
to top, and remove nsn3.mijndomein.nl
do you put _acme-challenge
in record name?
Record name? Were do i find that
I found it
How can i install Userlike plugin to my website?
