Username (e.g. epiz_XXX) or Website username
patangal.su ---- epiz_24632663
the webpage doesn’t open randomly it was working fine for so long now I don’t know what happed please fix , it shows this:
[email protected] thanks in advance
Welcome!
That is happening because you are forcing HTTPS, but don’t have an SSL certificate installed. You can either remove the redirect, or follow the guide (or video in the guide) below.
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
Step 1: Set up the domain on your hosting account
The first thing to d…
i did the following in the video as mentioned and it still doesn’t work please help
Now you just need to install it.
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client…
Also, you can upload images directly to the forum, no need to use imager.
i already did install the certificate yesterday but it still gives me the same error I don’t understand why
even after i got the certificate and added this from the control panel to the SSL/TLS section and upload them the website still doesn’t load. i don’t know whats wrong
system
Closed
June 25, 2022, 6:45am
9
