my site improject.top
it went down
Yet from my cpanel and everything ok
and I have not received any email
can you help me
it went down
can you help me
When trying to browse your site, I see a message saying “HTTP ERROR 500”. That means that your website or your application returns the response code 500 but no content. That’s typically caused by either:
- An error in your .htaccess file.
- An error in your script, but your script does not display any errors.
If you have a .htaccess file, try renaming that first and see if your site returns content then. If that doesn’t work, you can try to enable debug mode or error logging for your script so it at least shows or logs the reason why it doesn’t work. The process for that depends on the script you’re using, so you’ll have to check the corresponding documentation of your script for that.
It is a wordpress site
I do not know how I should rename the file .htacess
however before everything worked then after my random check I see it is down.
I do not know how I should rename the file .htaccess
You just rename it to anything else. Simply make sure that the setting to see hidden files in File Manager is enabled and then find a file called .htaccess in your WordPress installation directory and rename it to anything else like: HTBACKUP.
Doing so will make .htaccess inactive and you will be able to check if the error was caused due to misconfiguration in the .htaccess config…
Have a good day!
Mike
I solved
Thank you for your assistance
