my sites are having errors such as 502, 520, 524, etc… But when i ping them they respond fine with only few loss. is this with in your server or do I need to do something to optimize my sites. here is the url of my site. optimaxsystems.ml
If you can ping your website, that means you’re not pinging us, because our servers block ping. 520 is a Cloudflare error, which means you’re not pinging us, but only pinging Cloudflare, which doesn’t tell you anything about your hosting account.
It’s possible that your website is affected by this issue: Unreliable websites on IP address 185.27.134.150
Okay admin, thank you. Is there anything I can do?
I checked your site, but I can’t confirm it’s a hosting issue. For example, this page loads nearly instantly for me: http://optimaxsystems.ml/index2.html
My best guess is that it’s some kind of slow plugin or theme, but I’m not sure.
Okay, Thank you admin. I’ll try to disable some plugins and modify some themes and I’ll get back to you if its still having errors
