Since Yesterday my website certificate doesn’t work anymore. It keeps giving self-signed certificate Warning even if i uploaded the signed certificate many times.
Is there any general issue with the hosting ?
Can you help solving this please ?
i have a comodo ssl certificate.
My domain is *.th3nest.com
i tried to reinstall the certificate but it keeps giving me warning. Only the default self signed certificate is served. don’t know why.
thanks
I’m sorry, but wildcard SSL certificates cannot be used at the moment. Any SSL certificate must be signed for the exact domain name.
thanks
I dont get it. It used to work just on last friday. What happened in just 2 days time ??!
thanks
The system started to work like it should? I don’t know why it worked before, wildcard SSL certificates have never worked as far as I know.
thanks
So you say that if i want that certificate to work it should be same as my website ? I must have a certificate for www.th3nest.com/wp/ ??
thanks
No, you only need one certificate per domain, not per subdirectory. You only need to have a certificate for th3nest.com (which also protects www.th3nest.com and th3nest.com/wp/ ).
thanks
That is what i had and it is not working since saturday
thanks
But you just said the certificate was for *.th3nest.com, not th3nest.com. The first is a wildcard certificate, which is not supported. The second one is.
If you are sure your SSL certificate is not a wildcard certificate, can you please paste the exact error message you see when trying to upload it? There are hundreds of different messages you could see when uploading a certificate, and I need to know which one you see to be able to help you.
