### Username (e.g. epiz_XXX) or Website URL
showing advertise instead of website
(please share the FULL error message y
ou see)
fbp110
September 24, 2022, 10:27am
#2
When I use a dig command, it shows you have BODIS as CNAME.
Because of this, the domain will always show an ad.
To fix this, you can remove the domain from your account and add it back again.
Here is a guide:
Login into your Control Panel (cpanel.epizy.com ) via the client area
On the Control Panel, go to “Domains” and select Addon Domains:
[addondomains]
This will open a new page. Find your domain and click on “Delete”:
[removeaddon]
Using the New Domain Name box, enter seguridadyservicios.tech and click on “Add Domain”
You are done! The only thing to keep an eye out is that the main directory for uploading files will be seguridadyservicios.tech/htdocs instead of htdocs/.
Like any DNS record changes, it can take up to 72 hours before your domain starts working again.
After doing the steps on the guide above, the main directory will be blog.paperonboard.in/htdocs
instead of htdocs
Oxy
September 24, 2022, 10:31am
#3
Best to do it like this in the article
since the main domain uses Cloudflare (paperonboard.in)
Alright people, who breaks your subdomains with Cloudflare integration, I have the solution.
Add cloudflare but “Manually”.
(This works only who have your own domain name.)
In this tutorial you see how to add Cloudflare at your own, and add subdomains with the SSL paddlock in your URL too.
Disable the “integration of cloudflare” on cPanel.
[image]
Go to cloudflare, Log in and “delete the site” that you have in cloudflare, (if you have it)… just scrolling down the page to “remove site …
these don’t work either:
stories.paperonboard.in
sitemaps.paperonboard.in
The “Error 525 - SSL handshake failed” message means that Cloudflare didn’t find a valid SSL certificate on the backend server. This happens if you’re using “Full” or “Full (strict)” SSL mode without a certificate installed on your hosting account. There are two ways you can fix this: You can switch to Flexible SSL, which bypasses the need to have any SSL certificate on your hosting account. You can acquire and install a valid SSL
thanks for the assistance. I make my website up and running
system
Closed
October 2, 2022, 6:12am
#6
