epiz_31138950
My username is epiz_31138950.
I’m having issues with Cloudflare CDN, I’m directed to iFastnet.com Special offer and Discount Coupon when I visit my site, here’s some info
###DNS Record:
Type:CNAME; Name:freedom-tsky.ga; Content: www.tsky.ga; Proxy Status: Proxied; TTL: Auto;
###Name Server:
freedom-tsky.ga is my newly registered domain name, I want to use it to speed up tsky.ga, tsky.ga can be accessed normally.
Hope you can give me some advice, thanks!
This Topic uses Google Translate, which may not be accurate
KangJL
October 20, 2022, 8:02am
#2
zzyYesimola:
freedom-tsky.ga
This is what I see
You need to add domain to hosting account first
Domain needs to be pointed to correct nameservers in order to be added as parked domain
Before you can add your domain name to your hosting account, you need to point it to the InfinityFree nameservers.
The nameservers of your domain name are a setting at your domain registrar to allow you to host a domain name with a different provider. So you need to change these settings at the site where you bought your domain name. Most registrars have different panels and we can’t cover them all in this guide. For this guide, we’ll use NameSilo as an example.
Step 0: Find the correct names…
system
Closed
October 27, 2022, 8:03am
#3
