My website is not opening.
Hello, I have registered my website on your servers, but it is still inactive for 20 days. I checked dns and cloudflare for ssl but it is still not active, what is the reason for this error: hemenavans.com
Did you set the A record correctly pointing to the Server IP as listed in the client area? Also, please share your dns config of cloudflare (img)
KangJL
April 23, 2022, 4:04am
#3
This is what I see
Make sure you follow this
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com )
------- Set-Up Cloudflare -------
Go to Dash.Cloudflare.com and create a new account (Or log in to your existing one)
Add site (Blue Button)
[Screenshot 2022-03-08 7.03.04 PM]
Go…
Oxy
April 23, 2022, 8:11am
#4
CF (orange cloud) should refer to this IP
system
Closed
April 30, 2022, 8:12am
#5
