I took the free domain and my domain is not running… Check it rksharma.rf.gd Please let me know what problem is happened
hello
your domain works
you probably deleted the htdocs folder or is empty
and then the server does not know what to serve as a home page
if you have deleted the htdocs folder
create new folder and name it with htdocs
(chmod 755)
than put index.html (website) file in htdocs folder and you will see it work
all website files must go to htdocs folder
because it is a public folder (available online)
if your home page is called differently than index.php or index.html
then do this https://forum.infinityfree.com/discussion/comment/10817
i am not deleted the htdocs folder but still not working
OK then please copy this
<!DOCTYPE html>
<head>
<meta charset="utf-8">
<title>TEST</title>
</head>
<body>TEST
</body>
</html>
and in htdocs folder create new file
name it index.html
and paste this code inside
then save
Does your site have legs to run?
Just do that @OxyDac had said above!
I’m not exactly sure what you see exactly when you say when your domain is “not running”, but as far as I can tell, you’re seeing either of these issues:
- You are redirected to our 404 page. That is because your website’s code is redirecting people to http://rksharma.rf.gd/auth/login.php?action=login , which does not exist. Note that our servers (just like virtually all other web hosting servers) uses Linux, which has case sensitive file systems. That means
andhttp://rksharma.rf.gd/Auth/
can be different directories, and if the URL doesn’t have the proper capitalization, you get an error. - You get another error, which is because your domain name is new (it was created today) and hasn’t propagated yet. Read more about that here: https://infinityfree.net/support/why-doesnt-my-domain-work/
