So basically yesterday I had gotten my website ssl certified using ZeroSSL for the provider and when you try it on chrome it says secure or opera secure etc… But when someone try’s searching it up on edge it says not secure. I was reading an forum about this problem and how I can flow the traffic to https:// but I feel like doing that is not necessary. I feel like normally when someone searches samk.rf.gd on ANY web browser it should automatically be secure BECAUSE I already have it ssl certified. Can anyone help me out with this problem or any way I can fix something. Thank you.
What’s happening is that you are not redirecting all traffic to HTTPS, so you visit your website via HTTP and that’s why it shows as insecure. The following guide should help you:
Additionally:
ZeroSSL is supported on Edge, you can demonstrate that by visiting my ZeroSSL testing website https://thirdssltest.epizy.com. Just because a browser isn’t listed doesn’t mean it’s not supported, and since Edge is built on Chromium and Chrome is supported most Chromium browsers should be as well.
