My website is not working www.albustansign.com
My website URL is:
What I’m seeing is:
I’m using this software:
Additional information:
Can you please compile the template, as we need to know what is your problem?
im using infinity free hosting .when sign in infinty hosting i cant sign in to to the wordpress in infinity. its been a week my website is not showing . i edit the nameservers points in my domain software then also its not showing
Change the WordPress URL from HTTPS to HTTP by following these instructions:
  1. Go to your Control Panel, then click on “MySQL Databases”.
  2. Click on “Admin” near the database you want to manage.
  3. Locate a table called wp_options (it also depends on what database prefix you used to install WordPress).
  4. Edit the siteurl and home values to have HTTP URLs instead of HTTPS ones (for example, https://yourdomain would become http://yourdomain) and execute the query.
its not working
how i can i know my name server points
Check the knowledge base maybe?
according to your dns you pointed your name server correctly and i have see your website with wordpress
are you saying you cant login to admin account?
if yes
try this
http://www.albustansign.com/wp-admin
