This page isn’t working
instantrepair.tech is currently unable to handle this request.
HTTP ERROR 500
I am getting this error from a long time i have tried deactivating all plugins and themes but it still not fixing
Admin
March 14, 2023, 8:15pm
#2
Did you check this article already?
When trying to access your website, you may see a page which returns the status code “500”. In Google Chrome, you’ll see a page with the error code HTTP ERROR 500.
There are typically two reasons which can cause this error:
The PHP code has crashed.
The .htaccess file contains invalid rules.
Here are some things you can try to debug and fix this.
Fixing crashing PHP code
A HTTP ERROR 500 simply tells you that the PHP code has crashed, but gives no information as to why it has crashed.
Ge…
I guess My PHP code Was crashed
but now i am getting this error
Parse error : syntax error, unexpected ‘t’ (T_STRING) in /home/vol8_5/epizy.com/epiz_33709610/htdocs/wp-includes/functions.php on line 493
Fatal error : Uncaught Error: Call to undefined function wp_die() in /home/vol8_5/epizy.com/epiz_33709610/htdocs/wp-includes/class-wp-fatal-error-handler.php:239 Stack trace: #0 /home/vol8_5/epizy.com/epiz_33709610/htdocs/wp-includes/class-wp-fatal-error-handler.php(154): WP_Fatal_Error_Handler->display_default_error_template(Array, false) #1 /home/vol8_5/epizy.com/epiz_33709610/htdocs/wp-includes/class-wp-fatal-error-handler.php(58): WP_Fatal_Error_Handler->display_error_template(Array, false) #2 [internal function]: WP_Fatal_Error_Handler->handle() #3 {main} thrown in /home/vol8_5/epizy.com/epiz_33709610/htdocs/wp-includes/class-wp-fatal-error-handler.php on line 239
Username epiz_33709610 instantrepair.tech
Can Anyone Tell Me how to solve this error i cant get into my wordpress panel also
Admin
March 14, 2023, 8:34pm
#5
Looking at the file paths, it seems that there is some problem with the WordPress core files. This is how you can fix it:
WordPress frequently releases updates, which you can install through WordPress’ admin interface. Usually, this works without a hitch. But with some (big) upgrades, the upgrade fails half way and leaves you with a broken website.
Fortunately, you can still fix your website without any data loss, and this article tells you how to do that.
Download a fresh copy of WordPress
First of all, you will need to download a fresh copy of WordPress. You can download this from the official WordPress websit…
system
Closed
March 21, 2023, 8:29pm
#6
