Hello User im LightShineUser also my User ID is epiz_30056854 I was trying to upload like 10000 Files for Social Media Website i am making but it will not upload pls help me!!!
KangJL
November 2, 2021, 9:34am
#2
Since you did not write clearly, help yourself by reading these…
On all InfinityFree servers is a file size limit of 10 MB. It’s important to note that this is a file size limit and not an upload limit.
The difference is subtle, but important. An upload limit could be set through PHP settings, but this limit is enforced on the file system level. No PHP configuration can override this limit and it applies to files uploaded through FTP or the file manager as well.
Can the limit be increased?
No. The size limit is fixed and cannot be increased in any way. 10 …
InfinityFree has a file size limit of 10 MB on all servers. You cannot upload files larger than 10 MB.
Installing large scripts
A particular software package may be larger than 10 MB in size. Because of this limit, you cannot upload the archive directly and have it extracted on the server. However, you can easily upload the contents manually.
To do so, you will first need a good FTP file manager for your desktop and setup an FTP connection. See the how to upload files with FTP article for mor…
If you have an account with lots of files, you may hit the error Disk Quota Exceeded.
This error is typically caused by hitting the INODE limit of your account. You can view your account’s inode usage in the sidebar of your control panel. If your account is at or close to the limit of 30,000 inodes, that most likely is the reason you get this error.
In Linux file systems (and other Unix-like systems like MacOS), every file and directory is an inode. Having too many inodes on a system means tha…
system
Closed
November 9, 2021, 9:34am
#3
