ejabong
October 2, 2022, 11:26am
#1
Hello! I hope you’re all doing great!
So basically I was very confused to what happened with my website. I already changed the nameservers from my domain registrar.
My website at www.ejabong.tech works fine when there is a www in it. However, without the www, it points to a different site which looks like an ad.
Please see it for yourself.
https://ejabong.tech
Can anybody help me fix this?
Thank you so much!
It is a canonicalization error if your website doesn’t redirect to a specific URL. Go to your control panel and redirect your website to the provided URL. In my case, I does the same thing for the website I was facing the same issue.
fbp110
October 2, 2022, 12:01pm
#3
Most likely the effect of DNS Propagation:
If you’ve just created your account, or just added a new domain name to an account, you may be surprised that you are unable to view your website when using the domain. Instead you may see:
An advertisements page, with ?z being added to the URL.
An error saying “This site can’t be reached”.
This is usually caused by a system called DNS Caching. This article explains how DNS Caching works, why your website isn’t up yet and what you can do to see your website right now.
When will I be able to…
ejabong
October 2, 2022, 11:44am
#4
Hi KangJL! How could I remove the bodis cname in infinityfree? My nameservers are already infinityfree and I cannot find the cname of bodis. thanks
ejabong
October 2, 2022, 11:59am
#6
I did it just now.
The CNAME for bodis disappeared:
However, my link http://ejabong.tech still points to the ad page. I think it will be fine soon since the DNS record has just changed.
Thanks!
KangJL
October 2, 2022, 12:05pm
#7
Due to this
Once A record for base domain is the same as www subdomain, things will be fine by then
ejabong
October 2, 2022, 12:13pm
#8
The problem is I don’t know if there is any way to edit A record in infinityfree. Or should I edit it somewhere else?
ejabong
October 2, 2022, 1:07pm
#10
Thank you so much for your help!
ejabong
October 2, 2022, 1:09pm
#11
Thanks for your reply! It’s already resolved with the solution provided by KangJL in this thread.
system
Closed
October 9, 2022, 1:10pm
#13
