My website URL is:
http://www.fitnessonitsway.online
http://ketoaccelerator.gq
What I’m seeing is:
I’m using this software:
Additional information:
my both websites are not working from a week I have changed the name servers too
what to do ?
My website URL is:
What I’m seeing is:
what to do ?
For both domains, your nameservers settings don’t look entirely accurate.
The domain fitnessonitsway.online points to both the epizy.com nameservers and the nameservers of dns-parking.com. Because of this, the website won’t work half of the time. Please update your domain’s nameservers to only have the epizy.com nameservers and no other ones.
The domain ketoaccelerator.gq doesn’t seem to have any nameservers at all right now. Please check with your domain registrar (Freenom?) to make sure the domain name is active and has the right nameservers. If everything looks OK there, please contact your domain registrar for help, because all the nameservers are missing. If they don’t believe you, just send them this link to prove it:
now also I have changed the name servers ,now also both websites are not loading
it is showing error
I dont see the server ip
I dont know how you do that but I can not found nameservers from 20 countries
Sorry about that. I only looked at your nameservers, not at the status of the domain on our platform. Because the domain name fitnessonitsway.online is not assigned to any hosting account right now.
But since you’ve already configured your nameservers, you can just create a new hosting account with that domain or add it to an existing account as an Addon Domains or Parked Domain through the control panel of that account.
And what about the other domain ketoaccelerator.gq ?
That domain still doesn’t point to our nameservers. Are you sure you pointed correctly the domain to the nameservers and it’s active on their platform? If so, maybe try to contact Freenom support for help?
Yes I am sure I have pointed the nameservers correctly
A DNS lookup shows that the nameservers for ketoaccelerator.gq are still not set up correctly:
If you set them correctly through the panel of your domain name provider, please ask them for help with this. Because those settings are not being applied to your domain name.
As for fitnessonitsway.online, the database servers are still struggling at peak times due to old hardware. iFastNet is still waiting for some components to be delivered before they can upgrade the databases.
