Hello i cant reach to my forum its link assemble-gaming.com/forum it says while visiting “MyBB has experienced an internal SQL error and cannot continue.” please help
Hi
did the forum worked normal before ?
if not
yep it were working normal before.
thank you i just changed the password of the account and its changed also for database, its now fixed thanks.
there are a lot of problems with the missing files
look at all yellow (click on all yellow for more info)
https://www.webpagetest.org/result/190212_JQ_241a2ad60ca72d5047b51f389fee498e/1/details/
everything would work quicker without these problems because every little bit calls infinityfree 404 error page, etc.
the time is lost on that…
also after you upload the necessary files do not forget to purge cache in Cloudflare
