Nope , i don’t know why its not working , can u watch to my code? if is good
<?php
$ufff = $_POST['key'];
$dbhost = "host";
$dbuser = "user";
$dbpass = "pass";
$dbname = "epic...";
// DO NOT EDIT EVERYTHING BELOW THIS LINE
$link = mysqli_connect($dbhost, $dbuser, $dbpass, $dbname);
if(!$link){
echo "Connection failed: ".mysqli_connect_error();
exit;
$ufff = decrypt($ufff, date("Ymd"));
$ufff = explode("|", base64_decode($ufff));
$ufff = base64_decode($ufff[1]);
$sql22 = "SELECT `username`,`img_key` FROM `users` WHERE `img_key` = '$ufff'";
$result2 = $link->query($sql22);
if ($result2->num_rows > 0) {
$result2 = $result2->fetch_assoc();
if($result2['img_key'] != null){
$files = glob("images/*.*");
echo "<br>";
for ($i=0; $i<count($files); $i++)
$image = $files[$i];
$supported_file = array(
'gif',
'jpg',
'jpeg',
'png'
$ext = strtolower(pathinfo($image, PATHINFO_EXTENSION));
if (in_array($ext, $supported_file)) {
echo "<h3 align='center'><a style='color:white;' href='/".basename($image)."'>".basename($image)."</a></h3><br />"; // show only image name if you want to show full path then use this code // echo $image."<br />";
} else {
continue;
}else {
die(":p");
} else {
die(":P");
function decrypt($string, $key)
$result = '';
$string = base64_decode($string);
for($i=0; $i<strlen($string); $i++) {
$char = substr($string, $i, 1);
$keychar = substr($key, ($i % strlen($key))-1, 1);
$char = chr(ord($char)-ord($keychar));
$result.=$char;
return $result;
<html lang="en-US"><head>
<meta charset="UTF-8">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta name="robots" content="noindex, nofollow">
<title>GAMEBAN</title>
<link href="https://fonts.googleapis.com/css?family=Raleway:900,400" rel="stylesheet" type="text/css">
<style type="text/css">#title h1,body{font-weight:400;color:#eee}.divide,.outer{position:absolute;width:100%}#title h1,.trifecta,p{text-align:center}body,html{margin:0;padding:0;height:100%}body{font-family:Raleway,Helvetica Neue,Helvetica,sans-serif;font-size:14px;background-color:#101010}p{font-size:1.75em;color:#ddd;margin:10px 0 0}.divide{top:0;padding:0;margin:0;background:#1e5799;background:-moz-linear-gradient(left,#1e5799 0,#f300ff 50%,#e0ff00 100%);background:-webkit-gradient(linear,left top,right top,color-stop(0,#1e5799),color-stop(50%,#f300ff),color-stop(100%,#e0ff00));background:-webkit-linear-gradient(left,#1e5799 0,#f300ff 50%,#e0ff00 100%);background:-o-linear-gradient(left,#1e5799 0,#f300ff 50%,#e0ff00 100%);background:-ms-linear-gradient(left,#1e5799 0,#f300ff 50%,#e0ff00 100%);background:linear-gradient(to right,#1e5799 0,#f300ff 50%,#e0ff00 100%);filter:progid:DXImageTransform.Microsoft.gradient( startColorstr='#1e5799', endColorstr='#e0ff00', GradientType=1 );height:3px;border-bottom:1px solid #000}.trifecta .one,.trifecta .two,.trifecta>div{background-color:#eee}#title h1{margin:0 auto;padding:0;font-size:62pt;height:120px}#title span{color:#00BFFF}.outer{display:table;height:100%}.middle{display:table-cell; position:absolute;
bottom:0;
right:0;}.inner{margin-left:auto;margin-right:auto;width:400px}.trifecta{margin:0 auto;font-size:26px;width:80px}.trifecta>div{display:inline-block;width:14px;height:14px;border-radius:100%;-webkit-animation:bdelay 1.4s infinite ease-in-out both;animation:bdelay 1.4s infinite ease-in-out both}.trifecta .one{-webkit-animation-delay:-.32s;animation-delay:-.32s}.trifecta .two{-webkit-animation-delay:-.16s;animation-delay:-.16s}@-webkit-keyframes bdelay{0%,100%,80%{-webkit-transform:scale(0)}40%{-webkit-transform:scale(1)}}@keyframes bdelay{0%,100%,80%{-webkit-transform:scale(0);transform:scale(0)}40%{transform:scale(1);-webkit-transform:scale(1)}}</style>
</head>
<body>
<div class="divide"></div>
<div class="middle"><div class="inner">
<div id="title">
<h1>game<span>ban</span></h1>
</div>
</div></div>
</body></html>
