**My website URL is:www.hotelalice.in
What I’m seeing is:
I’m using this software: Edge/Internet Explorer
**Additional information: Receiving This message:
Unable to connect to the database. Please check the database connection parameters.
SQLSTATE[HY000] [1045] Access denied for user ‘epiz_24801819’@‘192.168.2.193’ (using password: YES)
Entering the correct password though.**
I guess that’s permission issue.
Kindly fix asap.
Thanks
Admin
November 17, 2019, 9:31am
4
sansoni2004:
Kindly fix asap.
I’m sorry, but who needs to fix what exactly? As I see it, you need to fix your script configuration.
And if there really is a permissions issue, can you please try to follow the steps from this article to reset them?
https://infinityfree.net/support/unable-to-access-phpmyadmin/
system
Closed
December 17, 2019, 9:31am
5
