MySQL connection refused error
My website URL is: http://galaxypixel.rf.gd
What I’m seeing is: 2002 - Connection refused
I’m using this software: NamelessMC
Additional information: When I enter all of the MySQL database information to get the website installed I keep getting the error of 2002 - Connection refused. I have entered the information multiple times and in different ways and keep getting the error. Am I entering something wrong or did my database become corrupt?
What info do you give to install your site? You should share it here that we check it but please censor your password :>
Database ip: 127.0.0.1
Database port: 3306
Database username: epiz_24900703
Database password: HIDDEN BY MOD
Database name: epiz_24900703_GalaxyPixelDataBase
Hostname: I have tried leaving it default of galaxypixel.rf.gd, I have also tried using the database hostname of sql307.epizy.com
Installation path: I have left it blank and I have put htdocs in there
Friendly URLs: disabled
Character set: unicode
Database storage engine: MyISAM
That is the problem, because you used 127.0.0.1 as database host. The correct database host can be found on the “MySQL Databases” section of the Control Panel. And uh oh! You didn’t censor the database password correctly! Change it to something else now, because it’s now compromised.
So I would put the host name in where the ip goes?
Would you try sql307.epizy.com as Hostname and 185.27.134.9 As database ip?
I tried what you suggested and I got error 2002 - Connection refused
Try using 192.168.0.197 as database IP, and leave the hostname and installation path as default.
@anon19508339, I don’t think the database IP you posted is correct, just because… (continues on this post)
That works. Thank you so much!
185.27.134.9 is the file manager IP. The database IPs are internal IPs.
