moodle installer fails to install because of mow version of maria db
version 10.2.29 is required and you are running 5.6.48.88.0
is there any fix for this??? is its just this low??? PHP is okay but mysql is rather low…
if none, ill just deactivate , thank you
Use softaculous to install Moodle. It will work.
Moodle is no longer supported on free hosting
it works, using softaculous. I just tried.
thanks for all the info, im trying to install now , but this is the error i get
did you not have error on installing moodle?
First remove all the files from your htdocs folder of your site then use softaculous to install
Admin
July 4, 2021, 11:10am
8
We currently run MySQL 5.6, which is indeed to low for the latest version of Moodle, which requires MySQL 5.7. Unfortunately, that’s not something you can fix yourself.
thank you for the response…atleast now i know the sql version… Ive already decided to just install a lower version of moodle ,
system
Closed
July 11, 2021, 2:27pm
10
