My question is simple. How can I connect InfinityFree with NameCheap?
I have a domain and I want to connect it to InfinityFree, but I want to use NameCheap BasicDNS
How can I do it?
EDIT:
I also use this domain for my minecraft server
How can I do it?
EDIT:
There might be a way of setting up some port rules on NameCheap to send http/https traffic to your infinityfree website and minecraft traffic to your minecraft server from the same domain name, honestly i’ve never used NameCheap and im unfamiliar with the options they provide
In theory it should be possible, Its an interesting problem
I guess you could try forwarding http/https trafic from your minecraft server to your infinityfree website, that might work too
just an idea
found this online it should do the job depending if your BasicDNS account allows it
Try to setup NS record pointing your domain to ns1.epizy.com and ns2.epizy.com
YMMV…
IF is meant for web hosting. Some ports may be blocked
This may violate TOS
HI
You request that your topic be deleted and also you decide to delete the topic question yourself
I returned it to its original state
Please understand that this is a forum
you asked a question and people here invested their time and effort to give you an answer
No private information or anything compromising was mentioned so that there might be a need to edit, let alone delete everything.
The topic also serve so that others who have the same question as you can find the answer
Thank you for understanding
