Your domain contains invalid or unknown nameservers.
In most cases, these should be removed.
my name servers are correctly
Can you provide the domain?
Your nameservers are not correct. They should be set to ns1.Epizy.com and ns2.Epizy.com. Also, they haven’t propagated.
So your registrar is Google Domains, right? You may wanna contact their support for more info if you face error when changing domains nameservers. Your current nameservers seem to be :-
my site is not working for now.
It won’t cuz the nameservers are messed up. fix them first.
remove the first three nameserver. keep only infinityfree’s
yes
okay i am deleted
that was the error we all pointed out from the beginning! after deleting those, now just wait for a few mins - hours for everything to be in line!
You are still mixing nameservers.
Please share a full screenshot of the nameserver settings at your domain registrar.
no i am not added
Let’s wait a little while for the nameservers to propagate. Maybe check back in an hour.
