I made my wordpress using localhost server and now I need to set it up on infinity free. Is there any way to bypass the 10MB limit? I can also split the zip but don’t know how…
Hi,
You can use FTP software to upload more than 10MB but… It must be extracted already or else it will be deleted.
hi
you can unzip files on your PC
and then upload part by part in the appropriate folders
retaining the existing folder structure
and create the corresponding DB
and keep in mind that here the base/address can not be called localhost etc.
