trazy.codes
I have files setup correctly, whenever I type in trazy.codes I get a weird page, is it an issue with the domain itself?
N/A
I used name.com for the domain
trazy.codes
N/A
It looks like you parked a different domain on your site using seedo. You probably want to remove this.
As you can see in the domain checker, your domain name has some bad nameservers assigned to them. Please remove them to fix your site.
