BHartfield
Im having a site built and I need this changes made is their any for the following to be changed on my site?
max_execution_time=300
memory_limit=512M
post_max_size=512M
upload_max_filesize=512M
KangJL
#2
You need to upgrade to premium hosting then
Welcome!
If you want full control over your php.ini settings, please upgrade to a VPS or dedicated server from iFastNet.
Thanks
Do I actual need the VPS version ($9.99 a month) or can I get by with the ($4.99 plan)? Money is really tight right now
I am not sure what plans support the settings you want to change. I recommend opening a ticket with iFastNet and asking them the best plan for you.
Yes, you can edit those settings in this plan, but once again do this:
Admin
#7
All of these limits are customizable in iFastNet. But the limits for the entire account vary by plan.
If I were you, I would just start small and upgrade to larger plans as needed.
system
Closed
#8
