@Admin Help me please. I tried using the Directory Privacy option in Files in cpanel, but now I am unable to remove that authentication popup. Kindly help. These are some images attached for reference-
https://geekyada.ga/Error/err.png
https://geekyada.ga/Error/err2.png
You can disable directory authentication manually by looking for the file called .htaccess
in the corresponding directory through a file manager or FTP client. You can remove the authentication lines from the file manually.
