Need Some Privacy info
Issue solved**
Please don’t ping Admin.
To force HTTPS, you have to use .htaccess rules and set up “Always use HTTPS” in CloudFlare.
https://blog.cloudflare.com/how-to-make-your-site-https-only/
Okk should i also add ?? In .htaccess about thoses ? I
You are using Cloudflare, so just set the redirect under Cloudflare SSL. Be sure to clear your cache.
Na. that wasnt issue i already did that but still wasnt working now anyways it was problem from cloudflare they fixed it now. Thank you everyone For your support.
