to com erro ERR_SSL_PROTOCOL_ERROR
https://www.experienciaincrivel.42web.io/erecton/
por favor me ajude ja testei todos os sertificados e nenhum esta me ajudando
TRANSLATED BY MOD
I have an error ERR_SSL_PROTOCOL_ERROR
Https://www.experienciaincrivel.42web.io/erecton/
Please help me, I’ve already tested all the sertified ones and none are helping me
Which provider did you choose? It looks like you chose Self Signed, which is not trusted, as the tool says. You will need to get one from GoGetSSL or ZeroSSL for it to be trusted in the browser.
vo fazer isso obrigado mas ja tinha feito e não deu mas vo fazer de novo
TRANSLATED
I’ll do that thanks but I had already done it and it didn’t work but I’ll do it again
Please type in English or use a translator .
If you did request a certificate from GoGetSSL or ZeroSSL, you have to install it. Follow this:
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client …
