No editing option in cpanal
My new cpanel has been working well but just recently, I can’t see any editing option for my style.css as shown below… is this an admin problem or could I check certain settings?
no%20editting%20option%20in%20cpanel
I read somewhere in cpanel that file size can’t be more than 1 MB, is there a way to edit this?
Infinityfree has file manager and you can use it :>
but I am just wondering if there is a way to increase the size of the file?
The file size limit depends on the hosting you’re in.
I am not sure about this but with the includes folder, should we only have files that are not actually active in that folder? such as activation files? From my experience, if I add anything in that folder, it will affect my url and sometimes won’t go back a directory. However, if I put most of my active files outside the includes folder, then it will work smoothly…
The includes folder is only for PHP files that need to be included in a file, not for active files.
ah… that makes sense I guess.
