My website url is www.razred.ga
I have turned on Cloudflare 2 days ago but there is no htttps what should I do?
You need to force your visitors to the HTTPS version of your website. The simplest way to do it is to login to your Cloudflare dashboard with the email you used to sign up on our service and the password you set using the reset password link given to you via email or your FTP password, clicking on your domain, then going on SSL/TLS, on “Edge Certificates”, scrolling down until you find “Always Use HTTPS” and turning it on.
Thanks a lot!
