solotf
May 16, 2021, 2:08am
#1
Username (e.g. epiz_XXX) or Website URL :cursonline
(please specify the website or account you are asking about): [https://cursonline.ml ]
Error Message: Status Nenhum certificado SSL foi encontrado
(please share the FULL error message you see): Status Nenhum certificado SSL foi encontrado
Other Information:
This is an English forum, please write your posts in English.
solotf
May 16, 2021, 1:01pm
#3
I have this problem = Status = (No SSL certificate was found) I did the entire step by step but still so can someone help me?
Can you please share the error in the full-screen screenshot?
Thanks.
solotf
May 16, 2021, 1:31pm
#5
the status does not go out of it
Make sure you copied the first CNAME record correctly, I would just copy and paste it a second time (don’t delete any other CNAME records so you don’t accidentally delete the working one). Make sure there are no spaces before it. If it says you cannot have duplicate records, you just have to wait.
Thanks.
solotf
May 16, 2021, 2:02pm
#7
solotf
May 16, 2021, 2:11pm
#8
the two above have already turned green but the one below does not come out of it
Status No SSL certificate was found
Uploading: image.png…
KangJL
May 16, 2021, 2:19pm
#9
Once turned green did you request for SSL cert?
KangJL
May 16, 2021, 2:24pm
#11
So did you install the private key followed by SSL cert?
solotf
May 16, 2021, 2:37pm
#13
yes but the certificate is still red
Please show a screenshot, it looks like your earlier one did not upload.
are both of the CNAME records at “Ready”?
Did you only change the cname records?
I was just about to ask that
solotf
May 16, 2021, 6:56pm
#20
I did all the step by step
