Followed all steps to install certificate including uploading key and certificate on cpanel, but somehow still showing the No SSL Certificate was found red status and showing error ERR_SSL_PROTOCOL_ERROR when opening https://allalgarvebooking.com
Could be some temporary issue/glitch with the hosting server or with Let’s Encrypt provider?
Both Ready and ssl issued today with expire date of 2021-09-26
Copied the secret key and certificate on the cpanel but still showing No SSL certificate was found status
Have tried Really Simple SSL but after many attempts the plugin was unable to generate the certificate
Actually the plugin was trying to get from letsencrypt.org certificate which is the same I’m trying to originally activate over the hosting
Plugin error: * Attempt 5. Invalid response received for request (POST https://acme-v02.api.letsencrypt.org/acme/new-order): rate limit reached - Error creating new order :: too many failed authorizations recently: see https://
Might be due to some temporary issue/glitch with the hosting server or with Let’s Encrypt provider
The SSL certificate seems to have been uploaded correctly, but doesn’t appear to be active.
I see your account is on one of the servers that was down recently. We had issues like this on other servers too, but those were fixed already. Perhaps the outage meant that the fix wasn’t applied here yet.
