my application is built with NUXT, i used NODE_ENV variable to generate 2 different api_file_path:
for development , i use my localhost
for production , i user infinityfreeapp folder path, but the problem that the page is not defining needed variable, they are undefined
Hmm, I don’t know if anyone here can help you with that. This seems to be an error entirely within your Javascript code or configuration. You may have more luck with this question if you ask people with more experience with this framework.
