I generated this query but due to work I was not able to answer(and it was closed), but I tried everything from renaming plugins,themes to inserting this code in function.php(as said by many other sites)
Idk why, but i was logged out of my wp ACC. and when I try to login again
[image]
this comes
my cookies are enabled, then also
if ( SITECOOKIEPATH != COOKIEPATH ) {
setcookie(TEST_COOKIE, ‘WP Cookie check’, 0, SITECOOKIEPATH, COOKIE_DOMAIN);
so what should I do now? how to login?
Try from another browser.
same error
proving that there is no prob in browser ig
i am not able to do anything to my site… I am completely locked out pls help
one more thing google search console also sent a mail regarding some crawler issue in my site and validating it but havent reverted back since 4 days… So i am waiting for their mail also
Can this issue be realted to login issue?
Samrridh:
and it was closed
It was closed because it was old.
The error on WP clearly shows that it is a cookie issue, so have you tried clearing your cookies?
Google cannot crawl past login pages, even when they are working, so most likely, that is unrelated. Google also usually give you a bit more detail than that when it encounters an error as well.
yes cleared it several times
any suggestion on what should i do now?
pasting console ss if it helps
is there any other way i can login or check the error which is causing this?
busy rn, will try and tell
Admin
February 20, 2022, 12:14pm
#12
On which site do you experience this issue in the first place?
Admin
February 21, 2022, 10:30am
#14
Thank you.
I see the same issue, and I think I know why.
When I check my browser, I see there are no (WordPress) cookies being set at all, which would explain the cookie error.
But when I check the login page response message, I should see a set-cookie
header that tries to set the session/csrf cookie.
But what I see in the response is this:
set-cookie wordpress_test_cookie=WP%20Cookie%20check; path=/; domain=.thedailybites.thespacedust.com; secure
As you can see, the cookie is being set for thedailybites.thespacedust.com
, not for thespacedust.com
, which is why the cookies don’t work.
I think that this is configured through the Site URL setting. You can change it like this:
On the Settings -> General screen in a single site installation of WordPress, there are two fields named “WordPress Address (URL)” and “Site Address (URL)”. They are important settings, since they control where WordPress is located. These settings...
thanks @Admin . There are 4 ways written, Is there any specific method you would suggest or all are equally fine?
Admin
February 22, 2022, 10:10am
#16
My personal preference is the database route:
they asking to find wp_options
but that is not visible in my database
everything is starting with wpwd
