Idk why, but i was logged out of my wp ACC. and when I try to login again
this comes
my cookies are enabled, then also
What plugin did you use? Disable it. Then use below to reset password to login
A Google search tell me that “You have been locked out” page is generated by the iThemes Security plugin. Maybe that plugin is also interfering with your ability to login?
