Not able to make SSL using really simple ssl -> (Attempt 2. The order is invalid, possibly due to too many failed authorization attempts. Please start at the previous step.)
rajendramansingh.com.np
We can’t provide support for third party SSL providers. If you want us to be able to help you with getting your SSL certificate, please get it with the Free SSL Certificates tool in our client area. That’s a service we provide that has been designed for and tested with our hosting so we can ensure that it works.
I deleted Cloudflare SSL for the site but I am still not able to create Really Simple SSL.
Do you want to redirect your visitors http to https?
  • Then Cloudflare SSL and redirection settings are enough to do that. (No plugins needed for http to https redirection)
  • You can also get a certificate from.infinityfree client area. Need redirection rules in .htaccess or WP plugins like Really Simple SSL
Here are SSL providers list in infinityfree
We generally recommend using Really Simple SSL, but only to configure your website to work well with HTTPS. We don’t recommend it for getting the certificate itself: we have our own SSL certificate tools that work well with our hosting.
If you insist on using Really Simple SSL, nobody here can stop you. But please don’t ask us to fix something which we specifically recommend against using.
I removed the SSL from Cloudflare and tried to install natively from infinityfree.net. However, it’s been more than 24 hours and still I don’t see the ssl. I see the message " Current Destination (not found)"
Did you add the CNAME records? Are there extra spaces in the records somewhere?
Thanks
Thank you everyone, I am able to get my website back.
