**My website URL is: http://sallystore.epizy.com/
**What I’m seeing is: all my PHP scripts are not being executed, while html is working only.
I’m using this software:
Additional information:
What is your PHP code, so that I can help you?
500 error
please enable display errors from alter php config.
i m testing the same code on windows machine using XAMPP and it’s working properly, while here its not.
I double checked the files/folders permissions (read execute), database information…Code is correct 100%.
i enabled display errors and checking errors.
You also need to upload on the htdocs ACVYNGIURA/Lib/Project.php
with a FTP client.
i fixed it after displaying errors, thanks guys.
