in the Middle was the following Epizy.com
A Free Website
Free Ecommerce Website
Free Domain
Free Web Domain
Cpanel Hosting
Webhosting Server
My own HTML
The simple index.html worked yesterday.
I then loaded a complex PHP site with a database. The page as stated above appeared.
I then just wanted to see if the original index.html would work. I deleted all the new code for the PHP site. This left the original index.html from yesterday to execute. The page that appeared was the same as above.
Only the Main Domain is suspended, but your domain is still active. You can’t access Main Domains directly, but after DNS propagation you can still access plerch.epizy.com. If you want the website to work quickly, configure a faster DNS resolver on your device.
So help me understand. My PHP application will work once the DNS propagation finishes. Is this the 72 hour delay? I deleted the PHP files - but If I reload - It will all work great once the DNS Propagation is finished? I do not want to do anything to make me permanently suspended.
It will all work great once the DNS propagation is finished. And you will never be suspended permanently, because the CPU limit isn’t going crazy after it was solved.
The CPU limit was going crazy on some accounts until July 28, when it was solved. So you shouldn’t be suspended, even if the Main Domain may look that the account was suspended, but in reality it will not be suspended. And I didn’t create the KB article; the Admin created it, and I posted it on here.
