epiz_26271091
Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/request.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/response.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/db.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/db/mysqli.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/session.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/session/db.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cache.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cache/file.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/url.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/language.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/document.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/customer.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/currency.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/tax.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/weight.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/length.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/cart.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/encryption.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/openbay.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : fopen(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/openbay.log) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22 Warning : fopen(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/openbay.log): failed to open stream: Operation not permitted in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22 Warning : fopen(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/error.log) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22 Warning : fopen(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/error.log): failed to open stream: Operation not permitted in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22
After installing Opencart via Softaculous the client page seems to be but I doubt that is the landing page of opencart and also the admin page seems to be having problems of some sort. (see errors above).
Is there anything that I need to do to get the website running? Thanks!
