Hi,
Firstly I try to install PrestaShop but it’s showing error about MySQL that length can be max 1000 bites or something like that.
And secondly I installed opencart, but I can’t log in to administration(password and username are correct) it still redirect me to log in section. Last thing I add some product to cart, but after clicking to basket to order… It’s deleted, and this happend to every product that I add there.
Why is this happening?
KangJL
August 30, 2021, 5:21am
#2
Current version of Prestashop is not supported on free hosting.
When trying to install software on InfinityFree (either by hand or through Softaculous), you may see an error message like this:
Could not make the query numbered : 16
MySQL Error No : 1071
MySQL Error : Specified key was too long; max key length is 1000 bytes
This error is caused by the fact that the script in question requires the use of the InnoDB storage engine for MySQL.
However, the InnoDB storage engine is not supported on InfinityFree. You can only create tables with the MyISAM st…
You can downgrade to lower version of Prestashop or upgrade to premuim hosting
KangJL
August 30, 2021, 5:27am
#3
As for OpenCart, this should answer your question…
Open Cart Couldnt be installed because we cant use folders outside htdocs , but opencart or softaculous asks the path to install data during installing , so just point it to htdocs folder and it will solve the issue , if you have login isssues on opencart , that not due to infiity free , its an opencart issue , fix is here → can't login to admin panel - OpenCart Community
THANK YOU ! IT WORKS great.
system
Closed
September 6, 2021, 6:15am
#5
