but when using a phar.gz file (sized 5.3MB), I get the following errors:
Warning: require_once(): open_basedir restriction in effect. File(/home/vol15_4/epizy.com) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol15_4/epizy.com/epiz_33609212/htdocs) in /home/vol15_4/epizy.com/epiz_33609212/htdocs/login.php on line 22
Notice: require_once(): write of 8192 bytes failed with errno=28 No space left on device in /home/vol15_4/epizy.com/epiz_33609212/htdocs/login.php on line 22
Warning: require_once(phar:///home/vol15_4/epizy.com/epiz_33609212/htdocs/phar_file/vendor/autoload.php): failed to open stream: unable to decompress gzipped phar archive "/home/vol15_4/epizy.com/epiz_33609212/htdocs/phar_file.phar.gz" to temporary file in /home/vol15_4/epizy.com/epiz_33609212/htdocs/login.php on line 22
does the phar.gz support ends here due to some policy? if so, why enable the phar.gz support for free tier?
Looking at the last two error messages, it seems that PHP first needs to extract your phar.gz file in order to access it. But the location to where it wants to extract the phar doesn’t have enough space to do that.
I just checked your website and it seems to be working now, but it’s possible the location for temporary files is quite small because very few people and sites use phar archives like this.
Just to be clear, we’re not blocking this due to policy. You’re just using a feature that’s very rarely used, which means you’re more likely to run into bugs and errors which we simply were not aware of.
If this ever happens again (or if you can reproduce this right now), we may be able to fix this.
But given that this is the third topic about phar archives, it seems to me that you can save yourself a lot of headache by just downloading the zip file of the google-api-client package, extracting that, and uploading the extracted directory. I can’t even find the phar in the official releases or documentation.
