the photo can not be displayed properly, nothing show but words and padding works normal
can we see the script you used, to make sure the format is correct
all?its so long
send as a file using upload link
can u see it ?thanks
place the code from the page in notebook save and then put file on infinityfree
I deleted the link because it contains sensitive details (also the password, encrypted in a BASE64 form). Also, you won’t need his code to help him, because I already have the solution.
@epiz_25881578, some of your files can’t be found on your server, and that’s why the photos aren’t shown. Please make sure you uploaded them correctly and if you did make sure that the path is the same as you defined it on the file, because Linux servers are case-sensitive; if not correct it.
thanks for a security required quick responce, bt going to add:
php is server side so …/photo/spiderhead.png, should be photo/spiderhead.png,
He’s not using PHP, and browsers nowadays understand how to manage URLs to files too.
hmm missed that major point there
so what should i do?
and new user cant upload new attachment
i dont understand but it work on my side
from before
what is mean by case-sensitive?
C is diffent to c, A is diffent to a etc
2k20(1).jpg will not work but 2K20(1).jpg will
no.it wont affect the evidence is that other photo with correct name and path also can t not be shown properly
