As you can see, our hosting does not support shell commands. This is an intentional security consideration, which means that shell access cannot be enabled on your account. Shell access may be available on some premium hosting plans, but I’m not sure.
And if the software you’re trying to use requires features which are not available on our hosting, that simply means you cannot run that software on our hosting.
